Motor mounts when doing headers...
Old Jun 2, 2006 | 02:19 PM
nyteryder167's Avatar
Default Motor mounts when doing headers...
Well, from what I've been reading, it's recommended to swap to tubular motor mounts when doing headers. Everyone that didn't do it wishes they did, everyone that did is very thankful. So, my question is, do I also go with prothane bushings as well or are the stock ones satisfactory.
BTW, my car shakes like no other when letting the SPEC stg 3 out anything less than dumping it, and I'd like to get rid of that. I'm thinking the mounts will help that problem, no? TIA!
Old Jun 2, 2006 | 02:25 PM
daryl2cb@yahoo.com's Avatar
think you got that wrong, poly mounts, not solid mounts, tubular k member is recomended.
Old Jun 2, 2006 | 03:40 PM
sdbrown84's Avatar
Poly motor mounts while you are changing headers is recommended. Will help stabilize the engine.
Old Jun 5, 2006 | 08:20 AM
So am I going to replace the bushings or the actual mounts? Both? I planned on buying a set of prothane bushings but if I have to buy the actual mounts as well, I guess I'll do that.
Old Jun 5, 2006 | 08:38 AM
TheBlurLS1's Avatar
That's what she said...
You just need the bushings. You take the factory "clam shells" apart and put the new bushings inside them, then bolt them up. There's a sticky at the top of this page with details.
The prothane bushings usually run about $50 and come with the bolts to put the clamshells back together.
Old Jun 5, 2006 | 08:47 AM
Awesome, thanks for clearing that up Blur.
Old Jun 5, 2006 | 12:12 PM
mrbobo's Avatar
yup, definatelty do the poly motor mounts.
Old Jun 7, 2006 | 09:40 AM
Hagarr's Avatar
Do the poly mounts!!! Do not wait till later.
Trust me. It will also stop all the freakin chatter with the Spec3. It worked for me
Brian
 Michael S. Palmer
