2000 Firehawk - No Crank
Old Feb 18, 2003 | 02:32 AM
RTCamaroSS's Avatar
Default 2000 Firehawk - No Crank
Ok guys, im working on a 2000 TransAm Firehawk. What we
have here is a no crank situation. I have checked all fuses
and relays and they are good, or have been swapped with
known good parts. One thing i noticed was that when the key
is inserted into the ignition, and the key turned to the ON
position, the security light in the cluster will continue
to blink. When you try to crank, the dash lights go out
(normal), but nothing happens, no crank, or activity from
the relays. I have swapped out the started with a known
good starter we had in the shop, still nothing. I have
checked all connections and wiring to the starter, and
everything appears to be fine. Because of the security
light blinking, im thinking its a theft deterent issue, we
checked the resistance in the key, and the chip has
resitance. I left the shop and went home to check the other
set of keys, and they have the same resitance. And thats
where i sit... Any ideas??? Thanks. Please email replied to
RTCamaroSS@aol.com in addition to the forum. Thank you!
Old Feb 18, 2003 | 09:58 AM
eallanboggs's Avatar
Default Re: 2000 Firehawk - No Crank
The PCM has a comparator register that looks for a match between the number of key cycles and the number of starter motor cycles. If this count is NOT a match the fuel pump is disabled. Your engine should start and run only till the fuel in the fuel rail is consumed then your dead in the water. That's the way the SECURITY system is supposed to work, but your not cranking even tho you get the SECURITY message. Strange! Time to get out the VOM and schematic
