car keeps dying?
Well the weather was finally ok to drive it again, but it still dies when i put in the clutch and let off the gas.
Could it be a vauum leak?
tunning issues? (had it tuned with ls1edit, was fine last year, didnt change anything).
does my cam have anything to do with it (224/224-114, havent changed it).
As far as i know, it runs fine in higher rpm you just got to give it gas, it just doesnt want to idle
It seems to die, just when i let off the throttle . Cause if i start it up it will Idle fine w/o surging. But if i give it gas, then let off IT will drop down to low and die, or pull up and surge. If i work the gas to stop it from dying giving it just a little throttle and then dont do anything it will return to idle fine.
<small>[ February 25, 2003, 05:59 AM: Message edited by: blown 346 ]</small>
