Jet-Hot Headers Install Questions
Old Feb 24, 2003 | 01:21 PM
SSCamaro99_3's Avatar
Default Jet-Hot Headers Install Questions
Which gaskets should I use? I was thinking about the GM gaskets and Stage 8 bolts. I also need t know about the O2 extensions. What length? I tried the search, but I didn't get what I was looking for. Thanks.
Old Feb 24, 2003 | 02:01 PM
slick98ta's Avatar
Default Re: Jet-Hot Headers Install Questions
You get the O2 extentions from jet hot,where you got the headers from.I believe there 12" long and $25 for the pair.
And reuse the stock GM manifold gaskets or buy new GM gaskets,don't use the one's jet-hot sent you.
Also, use your stock GM header bolts.They can be reused and work just fine.
<small>[ February 24, 2003, 02:03 PM: Message edited by: slick98ta ]</small>
Old Feb 24, 2003 | 03:32 PM
johnster's Avatar
Why can't you use the jet-hot gaskets?
Old Feb 24, 2003 | 07:00 PM
slick98ta's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by johnster:
<strong> Why can't you use the jet-hot gaskets? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You can but jet-hot's are more of a paper style gasket.GM's is a 3-layer metal gasket that holds up much better and no need of scraping the gasket material off if you want to take your headers off for whatever reason.
