maf question
Old Jun 4, 2006 | 10:44 AM
volksmech1's Avatar
Default maf question
ok here goes. i am building a fast 90 /90 set up and i was wondering if a 90 mm mass airflow sensor off of a o5 gto would work on my 2000 camaro ss with the ls1. i am trying to avoid th restriction as i am also running a larger lid and dont want a restriction in the middle. and please dont just suggest a speed density tune. thanks for all the help
Old Jun 5, 2006 | 12:17 AM
TheBlurLS1's Avatar
That's what she said...
If you want to run a larger MAF, I would contact your tuner and see which he prefers to tune. Most people like to run the z06 MAF, which is 85mm with no screen. The LS2 MAF will most likely not work with your application. The z06 MAF will need tuning to work properly.
Old Jun 5, 2006 | 04:48 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by TheBlurLS1
... see which he prefers to tune...
he/she
