idol problem
Old Feb 25, 2003 | 10:13 PM
Ultra Z's Avatar
Default idol problem
Just finished my motor and it ran like crap because I changed the injectors, heads and cam then used ls1 edit to fix it. I also drilled the throttle body then it ran good except at idol. It will idol fine for like 2 minutes then it starts to fluxuate reving up and down untill it cuts off. I was told this was because Its open header and its pulling in cold air on to the o2s and sending mixed signals ecu. Is this true? If not what else could it be?
