underdrive pulley question
Old Jun 5, 2006 | 09:05 PM
blackhawk J's Avatar
Default underdrive pulley question
My question about underdrive pulleys is if you slow down the accessories then wont the water pump be slowed down also causing the engine to overheat? I searched but couldnt find an answer to this question...
thanks
Old Jun 5, 2006 | 09:13 PM
Iron Sights's Avatar
Nope, my temperatures did not change a bit. The only thing you have to worry about is the alternator slowing down if you have a huge system in your car.
Old Jun 5, 2006 | 10:31 PM
1slowls1's Avatar
I would think it would be a prob in the automatic cars just cause they seem to idle lower than the m6's, and if you have a good size system than just put an optima battery and prob a cap. And I suppose you could also put an overdrive alt pulley another option. Ive also heard steering is a prob but have not witnessed this. maybe a bit tighter.
Old Jun 6, 2006 | 12:08 AM
Shinji43's Avatar
Yea, that was the first thing I noticed once I put my underdrive pulley on was the steering took a little more effort, not much difference though, got used to it after a day or so.
