header bolts
Old Jun 7, 2006 | 01:35 AM
shanekretz's Avatar
Default header bolts
just got my pacesetter long tubes and i tried starting the install earlier today...got the plug wires out but couldn't get the header bolts to budge. i was using a 10mm gear wrench...any suggestions? some type of oil/lubricant to loosen the bolts?
Old Jun 7, 2006 | 03:29 AM
Shallow Bay's Avatar
Are you sure you were turning them the right way? haha just kidding. Go to your local parts store and pick up a can of PB Blaster. Spray a good amount on each bolt and let it soak overnight. The next day the bolts should come out relatively easy. Good Luck!
