just got my pacesetters in!!! Are they the right ones??
Old Jun 9, 2006 | 03:40 PM
z28_n_tx's Avatar
hell im confused now....
Old Jun 9, 2006 | 04:18 PM
z28_n_tx's Avatar
Originally Posted by RrCoX22
ya normally the air fittings come off primaries #1 and #2 not like what you have plus that egr is out of place also and you should not have an egr provision... send that crap back and get what your supposed have
i checked my car and the fittings that are on the headers primaries are the same primaries as the stock manifold..for air...dont know if i made any cense
Old Jun 9, 2006 | 04:28 PM
2K2WS6TA's Avatar
To get it all straight, this is from my experience with my 02 T/A (should be the same for the 01 F body)
The headers are correctly welded, at least as far as I can see in the pics, the AIR fitting on the drivers side, will not fit on the fitting on the header, without changing the rubber hose, the angles are wrong, so you can block that off and remove the rubber AIR hose and metal elbow from the AIR valve at the rear of the intake, then if you want, you can go and get a length of hose (looks like a foot will be enought) and get it to fit, the passenger side fits fine, no mods needed. EGR, use a block off plate and it'll be fine
FWIW mine throws a p1415 (I think that's the number) code for the drivers side air about every 2 weeks, I just delete it
The holes in the collectors on the inside are for the 02 sensors
Old Jun 9, 2006 | 04:54 PM
z28_n_tx's Avatar
ok..so are all the pacesetters like this?? as far as the air fitting on the drivers side?? or did i just get a bad one??
damn this sucks ***....called tsp they keep telling me that everything is fine...i sent them the pics since 1 pm today but they havent even looked at them yet. i might as well just send the whole damn thing back and get my $$ and forget about this mod....
Old Jun 9, 2006 | 05:06 PM
2K2WS6TA's Avatar
It seems all of them are like that, don't be hasty in sending them back, they will work, I'm running a set like that now, with no problems other than the AIR code (just haven't messed with trying to get the hose)
Put them on, block off what you need to, and drive the car it'll be fine
Old Jun 9, 2006 | 06:35 PM
evrae205's Avatar
running without EGR or AIR CANT hurt your car. Just block off what you need to and install them. Both egr an AIR are useless garbage anyway. Delete them both and save about 20lbs of weight.
