Problem taking off the Ls1 intake
Remember, you wont be able to get those back 4 bolts out of the intake since the cowl will be in the way. Take some tape (doesnt matter what kind), and pull up on the bolts once theyre loose and wrap the shaft of the bolts really loose with the tape, so that the tape prevents gravity from letting the bolts fall back into the holes.
Behind your intake is the brake booster tube and a small round vacuum line. The vacuum line pops right off, and the brake booster tube can stay on the intake, as long as you disconnect it from the other end.
You need two people to pull it one. One to slowly pull on the intake, and the other to fish the brake booster hose through the mess of wires and hoses back there.
