Installing engine from bottom...with heads & headers??
Old Mar 19, 2003 | 10:00 PM
theblur98ss's Avatar
Default Installing engine from bottom...with heads & headers??
Just curious if I can install my engine from the bottom with the heads and headers already on it. I took it out as a shortblock pretty easy and figured it would save time to put it in assembled. I'm worried about the ground wires on the back of the drivers side head though. How do I get them back on the head while it's attached to the block?
Old Apr 1, 2003 | 10:51 AM
TreeGreenZ's Avatar
Default Re: Installing engine from bottom...with heads & headers??
ttt......I think the only way to do it, is to have a 6 year old girl sitting around with arms skinny enough to do it. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Apr 1, 2003 | 10:59 AM
Fireball's Avatar
if you disconnect the harness thru the firewall and a few other places...the whole harness can be pre-wired to the engine only leaving those few connections (at the pcm, 2 thru the firewall and many a few others) to be reconnected. the transmission, headers, heads, intake (everything) can be connected to the engine when installing from the bottom
