Plugs change, cut plug wire
To do that I had to pull plug wires from the coil packs - I was tired, I suppose, and thouse wires are hard to take out, so I tried to use a screwdriver and accidentally cut the rubber isolation on the plug wire, the rubber end of the wire which goes around extending [from the coil pack] plastic tube, which covers electrode on the coil pack. Cut is about 1/2-1/4 inch. I turned the engine on and checked for sparks/irregularities. Everything was fine.
- do you think a wire cut like this can affect anything and should I replace it with a new one??
_____________________________________________
btw, factory plugs (NGK 5PC, or something like that) on the driver side all had gaps at 0.060 - 0.061 (my car has 64kmiles on it), with a white spot on the top electrode, which I assume is the platinum disk, so I guess rumors about stock plug being garbage are highly exhagerated
