1.8 seconds
Old Mar 29, 2003 | 07:41 PM
2002 Trans Am's Avatar
Default 1.8 seconds
3825 race weight bone stock A4 02 TA, what do you guys think will drop an ET down 1.8 seconds?
Thanks.
I was thinking
Lid/filter, FTRA, Corsa catback, ported TB, QTP LT headers, cat Y pipe, cutout, Vig 3200, 315 nittos, LCAs, what else?
BTW no raceweight reductions
Old Mar 29, 2003 | 08:07 PM
Chris99WS6PWTMET's Avatar
Default Re: 1.8 seconds
Nittos and convertor alone could net you a sub 1.8 60'. The weight is whats gonna kill you. Mine is a sled also, but full interior and lowered is how I run mine. My best on Nittos w/ a SY3500 is 1.66, weighing in at almost #3700.
Old Mar 29, 2003 | 09:42 PM
Last time I raced I was 3720, I put that # out there because I figure 17x11s and the extra rubber from the tires should add a few pounds, doubt that much, but I just like to make sure
Old Mar 29, 2003 | 09:54 PM
INSSANE's Avatar
I don't think he meant 60ft.
I am thinking that 1.8 seconds is alot to drop with just external.
This is what I see...
vig - about .5
headers - about .2-.3 off the .5
catback, air, and tires, mabybe another .1 and some MPH
If you are running a 13.3 lets say, assuming you cut at least a 1.7 - 1.8 60 these mods should get you to 12.5-12.4. That should be aboout right considering you have the LS6 intake.
What I would ALSO do is:
-crank pulley worth maybe another .1 or .15
-hals make you consistent and sometimes takes .1-.2 or more off because of better 60 times
-computer tuning for shift points at least, this can make your car faster by another .1-.3 depending on what is done and how badly the car needed it.
The hals can wait, but I would at least do the crank pulley and a shift point or full tune.
Keep in mind that these are guesstimates and the law of diminishing returns.
I would say with the mods I suggested, you may be able to hit 11s, but your car is a bit heavy.
Good luck!
Nick
