need help with O2 sensor
Old Jun 16, 2006 | 11:48 PM
tsench's Avatar
Default need help with O2 sensor
my sensor bank1 driver side is not reading at all...i reset the comp still having code on the scaner and change a new..sensor still nothing happen some one know anything about this please help thx
Old Jun 17, 2006 | 12:46 AM
TheBlurLS1's Avatar
That's what she said...
Did you check all the fuses? You could trace out the wires and make sure they aren't burn as well.
Old Jun 17, 2006 | 11:58 PM
tsench's Avatar
i didnt check the fuse but...my wire nothing happen i think my comp not reading it is there any other way to restart my comp...let it read again
Old Jun 18, 2006 | 10:40 PM
tsench's Avatar
anyone?
Old Jun 19, 2006 | 01:18 AM
Luna's Avatar
The proper way to reset the PCM is key on, car OFF, pull the PCM IGN and PCM BATT fuse from the fuse blocks in the engine bay. Wait 10-15 mins. turn the key off, replace the fuses, start the car.
Hopefully that does it for you
Old Jun 19, 2006 | 11:33 PM
tsench's Avatar
thanks ill try it tomorrow
