Spraying out the radiator reserve
Old Jun 24, 2006 | 12:18 AM
ChocoTaco369's Avatar
Tech Resident
Originally Posted by TheBlurLS1
If it is a blown head gasket, now's the perfect time for a set of $900 TSP CNC'd heads.
and pistons, and install, and a tune...this is gettin' pricey for the dood, dood
Old Jun 24, 2006 | 12:55 AM
strokedls1's Avatar
I have seen ls1's make great power, but blow coolant on high rpm passes. It is definately a blown head gasket. Doing the pressure test on the cooling system is the easy way to figure out if the gaskets are leaking.
Old Jun 24, 2006 | 02:27 AM
BLK02TA's Avatar
You talkin to me or him? If it was a blown headgasket wouldnt the coolant be low?
Old Jun 24, 2006 | 11:18 AM
99HARDTOP99's Avatar
yeah dont know if i can help ya there. If nothinng is leaking or spraying anywhere i wouldnt worry about it. What happens when you run your car hard for 5 mins or so? I mean do you smell it worse then or still nothing? Just to ease your mind you could get a compression check done just in case.
Old Jun 24, 2006 | 11:51 AM
strokedls1's Avatar
I was talking to him. If your radiator is low then you know you have a problem. Pressure test the cap and system to make sure no issues are present. If you need a new cap try to get a stant. Otherwise maybe a good idea to buy an lt1 radiator. It has twice the capacity of a ls1 radiator, but have the exact same external and mounting dimensions. You just need to block off the heater core connections.
Old Jun 24, 2006 | 12:37 PM
Shoulder Shaker's Avatar
Yeah it sounds like a blown head gasket. I had the same problem last year. The car would run fine until I get on it hard. THe temp would shoot up and coolant would sprew all over the engine. I tried burping the system and the same results. I took it to a dealership and they performed a test to see it any exhaust was getting into the coolent and BAM that was the problem. So they told me I had 1 of 3 problems. Crack block , cracked heads, or blown gaskets. I tore the motor down and we found that the gaskets did appear to be worn to say the least. Well I have just been able to replace everything so I will be able to advise in a few days if this indeed fixed the problem. Good luck on getting the problem solved.
Old Jun 24, 2006 | 12:54 PM
WS6nJAX's Avatar
Restricted User
i had the same problem a few weeks ago with the violent overflows at the coolant reservoir. mine ended up being 2 problems. a sticking stat and my secondary fan speeds not coming on after a hard run or highway speeds. i replace the stat and reset the fans for the stat and everything is fine now.
