spark plugs
Old Apr 12, 2003 | 02:42 PM
BLULS1Z28's Avatar
Default spark plugs
does anyone know how to get the pass. side rear spark plug out
Old Apr 12, 2003 | 08:39 PM
2001 White Ws6's Avatar
Default Re: spark plugs
Many people get it from underneath the car. How was the job? Time Consuming?
Old Apr 12, 2003 | 09:02 PM
chino_man279's Avatar
I removed the back two ignition coils to make more room back there. I slipped the socket on the plug from above, then I went underneath to get the ratchet on it. This seemed to be a very easy way to do it. When I put it back in, I found it easiest to also remove the O2 sensor, then put it all in from underneath. You can look in between the exhaust manifold and the block to see if you have the plug aligned in the hole correctly when putting it in too.... Hope this helps out <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Joe
<img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
Old Apr 13, 2003 | 02:34 AM
onyxxtreme's Avatar
you can get it out from the top
just gotta play with different extensions
sometimes i use the socket with the built in swivel, sometimes i use a regular socket
the first time i did a tuneup, it took 8 hours
i just did my second today, and took only 1.5 hours, most of that was just goofing off though
just make absolutely positive you put anti-seize on the new plugs, so the next time you only have to break them loose, and can finger them out
Old Apr 13, 2003 | 10:56 AM
BLULS1Z28's Avatar
it wasnt to hard the hardest part was breaking the plugs loose and trying to get the wires off
Old Apr 13, 2003 | 05:02 PM
Biochem's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BLULS1Z28:
<strong> it wasnt to hard the hardest part was breaking the plugs loose and trying to get the wires off </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ditto... and I have the cuts on my knuckles to proove it <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> Took me about 1.5 hours today and I basically followed this procedure: http://ls1info.com/article.php?sid=48
