Removal of ATI damper???
Old Apr 12, 2003 | 09:11 PM
Gimp98TNT's Avatar
Default Removal of ATI damper???
today when i started on swapping my cam i ran into a problem, I can't get the pulley hub off the crank. I've had the stock one on and off a couple times before and never had any trouble before.
Any tips would be greatly apperciated.
I've been thinking about using heat, but should i heat the crank snout or the damper hub?
TIA
Jim
<small>[ April 13, 2003, 06:40 AM: Message edited by: Gimp98TNT ]</small>
Old Apr 13, 2003 | 06:56 AM
Gimp98TNT's Avatar
Default Re: Removal of ATI damper???
Going to drive down to summit today and buy there damper puller not sure if it will work or not but im going to try it.
I'm also going to get out the torches should i heat the crank snout or the damper hub?
TIA
Jim
Old Apr 13, 2003 | 11:46 AM
Gimp98TNT's Avatar
Nevermind summit puller worked like a champ
