Timing Advance Missing
Old Apr 14, 2003 | 03:22 PM
DolfanZ28's Avatar
Default Timing Advance Missing
I was breezing through some ATAP last night and noticed that am am getting about 4 degrees less timing advance at WOT then I was when I dynoed the numbers in my sig. I am only seeing 22 degrees of triming at the very top of the RPM range as compared to the 25 - 27.5 degrees I was getting on the dyno. I have richened things up quite a bit as of late and my ATAP logs confirm this. Will leaning things out a bit get this timing back? Right now my MAFT settings are BASE: 15% rich and WOT: 6% rich and that is producing the following:
LTTRIMS 1-19 AVG: -2.00+
O2 AVG: .90
Any advice???
Old Apr 14, 2003 | 05:58 PM
felton316's Avatar
Default Re: Timing Advance Missing
It could be due to different driving conditions. Was there a temperature change? You measured once on a dyno, and the other while driving? Possible differences in load while driving? It could be so many things...
Old Apr 14, 2003 | 06:05 PM
DolfanZ28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by felton316:
<strong> It could be due to different driving conditions. Was there a temperature change? You measured once on a dyno, and the other while driving? Possible differences in load while driving? It could be so many things... </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually YES I changed my stat last week and my car runs about 30 degrees cooler on average. I didn't expect to have to change my MAFT settings becasue of a cooler stat.
Old Apr 14, 2003 | 08:17 PM
Chris99WS6PWTMET's Avatar
I assume you are also reading for Knock Retard? If not, then I would start there first.
