Owners of Dynatech LT come in...
Old Apr 14, 2003 | 08:19 PM
02CamaroZ28's Avatar
Default Owners of Dynatech LT come in...
I have pretty much made my mind on the dynatech headers for an install this spring. I am just wondering a few things about them.
1) how is the quality, fitment issues, or anything bad to say about the coating
2) If you hooked up all the necessary sensors, how was that....I see that their collectors have O2 holes, any other emission controls needed with them?
3) If you have this header with the LM, I heard they aren't as bad with rasp as other headers, if they are what have you done to quiet them down.
Any other info is greatly apprecaited, thanks.
Mark
EDIT: Any clearance issues, the car has eibach sportlines, I can make a custom Y and cats, its just the headers im worried about.
<small>[ April 14, 2003, 08:28 PM: Message edited by: 02CamaroZ28 ]</small>
Old Apr 15, 2003 | 10:39 AM
ROB'S SS's Avatar
Default Re: Owners of Dynatech LT come in...
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 02CamaroZ28:
<strong> I have pretty much made my mind on the dynatech headers for an install this spring. I am just wondering a few things about them.
1) how is the quality, fitment issues, or anything bad to say about the coating</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">the quality is real good. they require a little beating of the body to fit, but they tuck up real nice. would be good on a lowered car. plus they are extremely easy to put in. coating seems to be ok. no problems with mine. sealing the collectors is a problem though. the only way to completely seal them is to weld the primaries to the inside of the collector. thats what i did and no leaks at all. and you will need to cut your oil drain bolt in half to remove once the headers are on. i cut mine all the way back to the threads and still requires a little finess to remove.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">2) If you hooked up all the necessary sensors, how was that....I see that their collectors have O2 holes, any other emission controls needed with them?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">thats the ONLY emissions fitting they come with. nothing at all for the A.I.R. or egr. so running cats is out of the question which means you will need o2 sims also. theses are not emissions legal headers!!!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">3) If you have this header with the LM, I heard they aren't as bad with rasp as other headers, if they are what have you done to quiet them down.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">IMPO, the loudmouth sounds like *** with headers. you can put a bullet muffler in place of the resonator and that would tame it a bit.
Old Apr 15, 2003 | 10:50 AM
turbo'd stang's Avatar
My only problem is the collectors too. I have had them off at least 3 times, filling the tubes with high temp RTV to stop leaks. I too had to beat the body some to get them to fit. But as Rob said, once they are on, I have had no problems.
I would actually buy some of the Kooks headers if I had to do it again. Their stuff on the Mustangs is top quality.
Old Apr 15, 2003 | 09:27 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">you will need to cut your oil drain bolt in half to remove once the headers are on. i cut mine all the way back to the threads and still requires a little finess to remove.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is the first that I have ever heard of this needing to be done. I really don't want to have to dut the drain plug, becuse of the magnet on the end is useful. I also change my own oil so this isn't sounding too good. Please tell me that I can do it without too much hassle.
Anyone else chime in on the subjext also?
Mark
Old Apr 16, 2003 | 06:58 AM
Fireball's Avatar
I have no problems getting my oil plug out with my dynatechs on (no cutting required)
Old Apr 16, 2003 | 01:15 PM
ROB'S SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fireball:
<strong> I have no problems getting my oil plug out with my dynatechs on (no cutting required) </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">there you have it. one yay, and one nay. take your pick <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 16, 2003 | 07:36 PM
The Juggernaut's Avatar
I just install dynatechs with the merge collectors.
They went in very easy.
No 'beating the body'
No cutting of the drain plug.
They fit and were easier than my old Mac's.
Old Apr 16, 2003 | 08:02 PM
ROB'S SS's Avatar
did they redesign the dynatechs? because i know im not the only one that had to cut his drain plug. as we all know, dynatechs are off-road FLP's which for a long time didnt fit for ****. beating of the body and drain plug clearances were very poor
Old Apr 16, 2003 | 09:03 PM
GeorgeC's Avatar
FWIW, I had to install a shorter drain plug as well (I just bought a really short one, instead of cutting mine).
Things are worse now, since my Dynatechs have taken a serious beating from a few excessive wheelstands, and they have been bent even closer to the drain plug...
I've been very pleased with mine, but I'm looking into some 1-7/8" headers in the future (from TR or Kooks...). <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 17, 2003 | 07:54 AM
Fireball's Avatar
FWIW...I run the stepped headers...not sure what difference that makes in locations (1 3/4 to 1 7/8) with a standard 3" collector
