fittings for back of intake...
Old Jun 22, 2006 | 12:33 PM
Slow Z28's Avatar
Default fittings for back of intake...
I have one hole which will be for the MAP sensor on the back of the sheet metal intake. BUT, I still need a hook up for the power brake booster, as well as that little line that comes from what looks like the heat/a.c. area. Anyone know of a specific fitting that could be put in there for all 3 hookups?
Old Jun 22, 2006 | 01:22 PM
daryl2cb@yahoo.com's Avatar
you could use a t that would go from 3/8 to two 1/4's then put 1/4 adapters to the a/c area, the other 1/4 would go to the air check value if you still have it, and the 3/8 would go the the brake booster. or actually a strait 3/8 through that has two 1/4 outlets on it would be the best thing. check the help section of your local autoparts store.
