6L intake
Old Apr 15, 2003 | 04:36 PM
99Z284MAC's Avatar
Default 6L intake
I am building a 422 to put in a 69 Camaro SS would I benifit from puting the 6L intake on instead of the LS6 intake?
Thanks in advance,
Mark Culbertson Jr
Old Apr 20, 2003 | 05:49 PM
WILWAXU's Avatar
Default Re: 6L intake
Well.. with your under hood clearence, you may be able to use it...
My try posting over in the Conversion and Hybrid section to see if anyone else has tried this.
Old Apr 21, 2003 | 05:35 PM
01 NBM SS's Avatar
I was reading about this in my ls1/ls6 performance book. The 6.0l intake will provide a better low end torque curve but that is it. It will even hurt you in the high rpm range. I would go with the ls6 intake.
Old Apr 21, 2003 | 06:50 PM
Speedfreaks101's Avatar
Here is flow bech infromation that I have seen the 6.0 Truck intake on ported heads compared to the LS6 intake and LS1 intake. The following is for ported LS1 heads on the same bench.
Intake .200 .300 .350 .400 .450 .500 .550 .600
LS1-------141--185--205--222--232--241--251--258
6.0--------163--206--224--237--249--262--265--270
LS6-------166--211--229--244--257--269--277--283
I do not have any port volume stats.
Hope this helps,
Bart
