O2 extensions
Old Apr 16, 2003 | 09:16 PM
Quick98SS's Avatar
Default O2 extensions
Is it possible to melt the o2 extension if they are too close to the header? I mean the heat shroad around the wire? Because there is no way to raut them away from the header.
Thanks
Tim
Old Apr 16, 2003 | 09:34 PM
Tin Indian's Avatar
Default Re: O2 extensions
Are you talking about the drivers side. If so, you will find a threaded bolt hole in the side of the block. Buy a short bolt that fits in the hole. Then get an aluminum clamp that the wire will fit in. This clamp will be held to the block. Autozone has various wire clamps that will work.
