Throttle body question, concerning idle speed.
Is the plate steel? If so couldn't I weld the hole up then drill it to a size that suits me?
If I found someone with tuning software, would it be easier to have the idle lowered that way? Can the idle be lowered with simple tuning?
Thanks
Dave
Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ April 21, 2003, 11:44 AM: Message edited by: TaTommyWS6 ]</small>
Basically you can only go down so far, if idle is higher from a ported TB then welding the hole up and making a smaller hole can get it back down to stock, but if the IAC is opening up then you have gone to far so as they said it will compensate for it.
Bret
