how to fix banging?
Old Jun 29, 2006 | 01:33 AM
99 Predator's Avatar
Default how to fix banging?
just got my car back and it sounds awesome, but when i pin it either the y pipe or the drivers side header is banging the floorboard, im really not sure which one it is. is this common? and how can i fix this?
Old Jun 29, 2006 | 01:38 AM
Lethal_Ws6's Avatar
Mine used to do the same thing, lol .it naturally fixed itself..
Old Jun 29, 2006 | 02:32 AM
TylerDurden28's Avatar
+2 on that!
Old Jun 29, 2006 | 02:56 AM
300bhp/ton's Avatar
Yes it's common. Adjustment of the Y pipe may help but you need:
-poly motor omunts
-poly tranny mounts
-Mufflex Y pipe hanger
All are pretty cheap and available from Thunder Racing. Although it's a shame you didn't do the mounts when you had the exhaust off.
Old Jun 29, 2006 | 11:29 AM
senicalj4579's Avatar
Originally Posted by TylerDurden28
+2 on that!
+3 on this.
what i did was wrapped some transmission cooler hose around the full diameter of the pipe where the pipes are touching any floor boards or metal or whatever. then i took a tie strap and slid it through the trans. hose and tightened the tie strap. i did this on 5 places. works great
Old Jun 29, 2006 | 11:35 AM
stangbangin69's Avatar
same prob here... i used header wrap and put it around the bangin spot then took a couple of worm gear clamps to secure it... no probs whatsoever since....
