cutout problem, too low.
Old Jul 3, 2006 | 04:41 PM
pcgamer4life's Avatar
Default cutout problem, too low.
After fighting two different exhaust shops to install it, this one finally did. I was excited, got her home and took a peek. This is what I saw.
Clearance issues anyone? I haven't snapped the flange off yet, I've only driven highway with it on, from the shop home. Spec-*******-tacular. The dolts put it way too far down the pipe, so the flange can't just be rotated up into the little cubby under the seat. Hurray for them. I specifically told them that the motor/plate should sit up under the rear seat and the pipe should be as close to parallel as possible. I guess I have to go back and get it fixed, I don't see how this is going to work.
By the way, the cutout sounds awesome.
Old Jul 3, 2006 | 04:53 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Unhappy
SORRY--That WILL NOT BE COOL....like u said..put it in the little indentation under then rear passenger seat..it looks like it was made for a cutout....OR..some have it BEHIND the axle at the bend where the I-Pipe is about to go into the muffler.....[ under the seat is best imo] G'luck BTW..that shop is run by Mental Cases.
Old Jul 3, 2006 | 05:11 PM
TORCHD 02 TA's Avatar
ohh man that is terrible....do you want me to get a pic of my cut out you?
Old Jul 3, 2006 | 06:04 PM
Jimmard's Avatar
Yeah that is way too low. Here's mine, I had a turndown put on it because it was too close to the rear seat and it was heating it up so bad that the interior of the car started smellin really bad.
edit: and I just realize it appears one of the bolts is missing a nut
Old Jul 3, 2006 | 06:09 PM
SUCK MY SS's Avatar
why didnt they just make it shorter?
Old Jul 3, 2006 | 06:10 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Man, were they mad at you for any reason? I would make them fix it if you can.
Old Jul 3, 2006 | 06:22 PM
I called and they said that I could bring it back on wednesday (closed for holiday tomorrow) and they'd see what they could do. The guy said "My welder told me that it was a problem, and that was virtually the only place he could put it." Dumbass. I do plan on printing out a picture I found on here and taking it with me. What a dolt!
On a side note, I've been driving around with it (without the elec. plate, just the cutout) and man does it sound incredible! I supposed I can get used to my change rattling and butt vibrating, it's worth it. I turned so many heads just cruising at ~35mph. I might just ditch the electric plate and get some of my money back, I don't think I'll have have this baby closed!
Old Jul 3, 2006 | 06:29 PM
Jimmard's Avatar
You can cure a lot of that rattling with a turndown pointed down and slightly out. Cured a lot of my rattles.
 Michael S. Palmer
Old Jul 3, 2006 | 11:04 PM
TheBlurLS1's Avatar
That's what she said...
That's ******* histerical. Someone needs a ball kick for that kinda work. Also, get rid of those wing-nuts or you'll be dragging the E-cutout down the highway. Some ny-lock nuts and loc-tite should do you nicely.
Print out this picture and tell them to rotate it untill it's in the slot provided.
Old Jul 3, 2006 | 11:33 PM
Lithium's Avatar
SSU's Drunk Typing Whore
holy hell that is low, definitely take care of that.
Old Jul 4, 2006 | 12:42 AM
staringback05's Avatar
lol how hard is it to just rotate it?, honestly i would have had major issues with them...they didnt let you see what they were doing?
