headers. what do i need?
Old Jul 3, 2006 | 11:53 PM
ski23's Avatar
Talking headers. what do i need?
plan on ordering some pacesetter coated race style headers soon.01 ss 52k miles (whos got the best price shipped to my door sponsors? ) what else do i need?
24" o2 ext
o2 simms
possibly new header gaskets?
header bolts or use stockers?
anything else? thanks for any info/tips
Old Jul 3, 2006 | 11:56 PM
Lithium's Avatar
SSU's Drunk Typing Whore
02 simms are optinal. If you can live with the SES light I suggest that you do so.
Header gaskets - only if the ones you took off need to be replaced. Otherwise use the stockers.
Stockers as well. The locking header bolts can be a pain in the *** if you ever plan on taking them off.
Take your time! Its pretty easy.
Old Jul 4, 2006 | 12:02 AM
TheBlurLS1's Avatar
That's what she said...
Do a search, this same thread gets started about 5 times a day.
I'm going to also suggest a set of poly motor-mounts, which I suggest about 10 times a day.
Old Jul 4, 2006 | 12:23 AM
Lithium's Avatar
I still never put those ******* in...I should of though cause I know I am going to regreat it.
Old Jul 4, 2006 | 02:00 AM
SatanzWS6's Avatar
i got mine from SpeedInc---->
i paid the the price thats on their site and not a penny more. it was free shipping and tax free. you should check them out. as for the o2 ext, get em, unless you have no problem extending the o2's with the kit they send you.
Old Jul 11, 2006 | 05:37 PM
dalejr8ls1's Avatar
O2 extentions, gaskets(steel)...you wont need O2 sims if you plan on getting it tuned they can just turn the rears off, probly dont want the SES light on all the time, you wont know when anohter code is thrown that may be important...
Old Jul 11, 2006 | 09:26 PM
candidate zero's Avatar
I just did my Pacesetters on my '01 SS w/ 55k and I got the Pacesetter race LTs. They came with bolts. 12" o2 extensions worked perfect for mine. o2 sims are optional, I'd prefer to just have the rear o2s tuned out anyway. Reuse the stock gaskets or get new GM ones, the paper ones are ****.
I'd recommend two ratcheting wrenches, a 10mm for the stock manifold bolts, and a 7/16 for the Pacesetter bolts. Remember to PB blast the bolts before hand to make things alot easier. On the passenger side, I pulled the starter and the header slid right in and bolted up fine. On the drivers side, I pulled the plugs and the steering shaft, and the header went up in.
Old Jul 12, 2006 | 09:22 AM
TheBlurLS1's Avatar
If the heads on those Pacesetter bolts are 7/16, I'd imagine the threads would be standard too?
99% of people reuse their stockers. PS just so someone doesn't get spooked, I didn't have to remove a damn thing to put my Pacesetters in.
 Michael S. Palmer
Old Jul 12, 2006 | 10:12 AM
nyteryder167's Avatar
I reused my stock bolts and gaskets, both worked fine. I HIGHLY recommend the 10mm ratcheting wrench as stated above, it'll save lots of time and bloody knuckles. Poly-motor mounts are an excellent idea as well.
Old Jul 12, 2006 | 10:14 AM
zboner's Avatar
yup, used my stock bolts and new gaskets from GM
Old Jul 13, 2006 | 01:48 AM
I don't know, I used the Pacesetter bolts that came with them, they're were 7/16, and they all started by hand and tightened down fine, none have come loose yet.
Old Jul 13, 2006 | 01:52 AM
SatanzWS6's Avatar
same here. except, i lost 2 of the bolts that came with em so i just used 2 of the stock ones. it all worked out fine.
Old Jul 13, 2006 | 01:57 AM
Maybe Pacesetter decided to go with a bigger head and same threads? I really have no clue.
Old Jul 13, 2006 | 11:33 AM
ShevrolayZ28's Avatar
And I still didn't follow your word
I like a quiet cabin so I was hesitant to install the poly mm's. But I can't keep the damn ypipe from hitting the floor! Every time I stomp the gas, I get the bangy-bang. Now I'm installing the poly mm's during my HC install.
Old Mar 11, 2007 | 08:28 AM
02BEAST's Avatar
How tight should the header bolts be I'm hearing 18 ft/lbs of torque do I need a torque wrench then also?
