Poly Mount Vibration
Old Jul 8, 2006 | 02:44 AM
ss4chad's Avatar
Default Poly Mount Vibration
Since I have put in the Poly mounts (motor, tranny) the car shakes quite a bit until I shift into overdrive. Is this normal?
Old Jul 8, 2006 | 03:35 AM
TheBlurLS1's Avatar
That's what she said...
Yes a little vibration is normal and it's probably caused by the trans mount. I noticed some when I installed mine (already had motor mounts), but forgot about it after a week or so.
Old Jul 8, 2006 | 08:06 AM
THE CHOP SHOP's Avatar
Did you install the preload plate with the trans mount? If you did remove it and sand the bumps down. If you already did this you kinda have to put some miles on it to not notice it as bad. Mine still vibrate a little but nothing that is to bad.
Old Jul 8, 2006 | 08:33 AM
Luna's Avatar
It is normal for the poly mounts to make you're car vibrate pretty hard for about 1,000-2,000 miles after they are installed. After they break in they will soften up enough that they extra vibration's they cause is minimal.
Old Jul 8, 2006 | 11:50 AM
ss4chad's Avatar
Cool, thanks guys. I thought I had a muffler bearing goin out or somethin that was makin it shake. I appreciate the input!!
Old Jul 8, 2006 | 12:14 PM
SIC LSX's Avatar
lol i did same post about 2 weeks ago with few mile it will go away
