A/C Compressor
Old Jul 11, 2006 | 06:32 PM
Phil99TA's Avatar
Default A/C Compressor
I've narrowed down a squealing noise to my AC system. I was hoping I just had a bad idler or tensioner pulley, but I'm getting a metal grinding noise when I turn the AC compressor pulley with the belt off. Is my compressor most likely shot or can I get away with changing the pulley? I am still getting cold air with it turned on (not strong, but never was).
Old Jul 11, 2006 | 06:37 PM
natronathon's Avatar
these compressors suck... to behonest, to take the pulley off you will need to pretty much remove the compressor anyway, so then the decision will be easier to make. I just replaced my compressor, and i think i will have to do it again... good luck... make sure if you get a new compressor thats rebuilt, make sure it has a lifetime warranty, im glad mine does...
Old Jul 12, 2006 | 08:45 AM
TheBlurLS1's Avatar
That's what she said...
Are you spinning just the clutch or are you spinning the whole compressor?
