Torque Arm Question
Old Jul 12, 2006 | 02:11 PM
litemup02's Avatar
Default Torque Arm Question
I'm going to be ordering the tsp true duals (3"). so i guess i need to buy an aftermarket torque arm, from what ive read Should i get an adjustable one? looking at the umi products. Thanks
Old Jul 12, 2006 | 02:25 PM
TheBlurLS1's Avatar
That's what she said...
The stock TQ arm will work fine and have plenty of clearance Clarence. UMI sells one just for duals though. Check the TD FAQ and you'll see a pic and some info.
Old Jul 12, 2006 | 03:00 PM
RrCoX22's Avatar
if you do get an aftermarket one... a chassis mounted one for that matter, you would more likely want to put that on before your duals as most setups don't clear the TA
....basically custom true duals is your only option
Old Jul 12, 2006 | 08:34 PM
TheBlurLS1's Avatar
Only option with a CHASSIS/BODY mount tq arm, just to clarify. With the stocker, or the trans mount from UMI, you should be fine.
Old Jul 12, 2006 | 08:47 PM
RrCoX22's Avatar
oh I'm deeply sorry I should have clarified
EDIT: actually now that I look back at it... I did
Old Jul 12, 2006 | 11:08 PM
TheBlurLS1's Avatar
Well I was confused.
Didn't mean to sound like a super-douche.
Old Jul 13, 2006 | 02:43 AM
litemup02's Avatar
Thanks guys, i'm thinking about a custom set-up too. either way i cant decide which muffler or bullet. Do you think the dynomax bullets would be any louder with my L.T.'s,ORY into a loudmouth 2 ? Just really lookin to get rid of the rasp...
Old Jul 13, 2006 | 02:52 AM
RrCoX22's Avatar
see Casey... he's going custom duals either ways
normally any duals will be louder and have a different tone than any other cat-back. Plus rasp starts to be a non-issue and the scavaging effect increases.
oh and your a joke for choosing the same setup I'm about to put on in two weeks... custom duals with dynomax bullets dumped... are you dumping them?
 Michael S. Palmer
Old Jul 13, 2006 | 03:32 AM
litemup02's Avatar
joke! dynomax bullets is one of the options for tsp setup. if custom, I might go with the magnaflows......not sure. Are you doing it yourself or with the help of a muffler shop? oh ya, dumped for now.
Old Jul 13, 2006 | 03:56 AM
RrCoX22's Avatar
im not all that experienced with welding, plus i'm getting a custom setup so the shop is gonna do it....
and you are dumping it... i've decided for you
Old Jul 13, 2006 | 01:26 PM
you2slo's Avatar
For the torque arm, you'll want a factory replacement part #s: 2205 or 2206. Also, they sell a torque arm relocation kit part#'s 2207-2210 depending on year and tranny.
Old Jul 13, 2006 | 04:44 PM
sswagon1's Avatar
gm sells a factory relocation mount?
