egr leak
Well, in the process, I did the egr mod. I reinstalled everything and now I have a small leak in, I'm guessing the o-ring. It's just a hissing noise and it has not effected the idle or anything, but it almost sounds like a supercharger whine...
Anyone had this problem? I ordered a new o-ring to try...Can I put some rtv or silicon seal at the top of intake where the egr bolts in to make it quit if the o-ring doesn't fix it?
Anybody have any input? anyone had this happen, or am i the only klutz on earth that this could ever happen to, and no one knows how to fix it?
so obviously you jacked up either the o-ring/nut/ect.
look over everything and find where the damage is... otherwise you incorrectly installed the tube end
Stuff like this just really bugs me. I'm using a new o-ring...I place the o-ring on the egr tube (at the top) and put the tube in the intake and tighten...the bolt is fine, the gasket's fine, and i am putting the tube in completely perpendicular to the intake...everything should be good...but it's not.
It just seems like every time i touch something, what happens next just doen't make any sense at all?!
Either way, i'm out of ideas...any suggestions would be greatly appreciated...if not, thanks for trying to help :-).
I want to keep the egr in order to prolong the life of the new catted y I have.
Just FYI...what is the difference in the 98-00 and the 01-02's. What was so different that the 01-02's didn't have to have the egr?
