pcv valve system
Old Jul 24, 2006 | 11:34 PM
shaun's Avatar
Question pcv valve system
hey guys i have a problem.
i was looking under the hood just being curious and i found some oil on the middle top passenger side valve cover. so there was a soft piece of foam taped to the pcv hose with electrical tape so i cut off the foam and tape and found that the rubber piece that the pcv valve sits in was pretty much broken in half.
so i managed to repair the hose with a few different size hozes in each other and sealed with black permatex and it worked.
but what is bothering me is that all the pics that i have seen[got pics off ls1howto] the pcv valve is by the throttle body and not on top of the pass valve cover.
so whats up with it?
Old Jul 25, 2006 | 01:03 PM
shaun's Avatar
any one?????????????????????????????????
Old Jul 25, 2006 | 02:27 PM
oange ss's Avatar
pcv valve location changed to front of engine for 99+ f-body's
Old Jul 25, 2006 | 03:03 PM
TheBlurLS1's Avatar
That's what she said...
Mine did the same thing. That tube that plugs into the driver side valve cover is probably broken or about to break also. I did the "slip smaller hose into bigger hose to make a bushing" thing like you did. I used some of the hose that I stole from my AIR system, which is just hanging out in my shop.
I actually got tired of it and deleted/plugged the whole sha-bang and now I run a breather.
