How To Remove The AIR Pump
Old Jul 27, 2006 | 06:20 PM
TORCHD 02 TA's Avatar
Default How To Remove The AIR Pump
That is all.. Any ideas
Old Jul 27, 2006 | 06:34 PM
'00_Z's Avatar
I'll go first before ya get 20 of the same response. Do a search, there are a few good write ups floating around. I found out the hard way!
Old Jul 27, 2006 | 06:36 PM
slowscott's Avatar
I think there is a writeup somewhere. From what I can remember you just unhook the hose that connects to each manifold and follow the hose back ripping off **** as you go. Depending on your year it will be different and you may have to plug a line that goes into the back of your intake manifold. Other than that you just disconnect anything connected to the two hoses that go to your exhaust manifolds.
scott
Old Jul 27, 2006 | 06:37 PM
SatanzWS6's Avatar
http://www.ls1camaro.net/sections.ph...ticle&artid=70
thats the best one i found when i did mine. its fairly easy to remove. the pump itself is located under the drivers side headlight.(incase you didnt know)
Old Jul 27, 2006 | 07:09 PM
Michael02hawk's Avatar
I think he means, how to actually get the bolts out holding the AIR in place.
I had one hell of a tough time getting those bolts out!
It probably took me about 15 mins to remove everything else, then another 1 1/2 hour to get the pump out, due to the bolts.
Old Jul 27, 2006 | 08:10 PM
ok i was wondering about a write up.. i know where all the hoses are, astated above how do you get it from under the drivers head light. i know that i will have to get under hte car and access it through the little access panel held on by three bolts. shouldnt be that bad.
anymore input would be greatly apreciated!
EDIT: rading the above link, do you need block off plate??? i do not have any nor did i know you needed them
Old Jul 27, 2006 | 08:28 PM
mcamp001's Avatar
http://www.bowlingss.com/Mods/InstalRepairl Items/Removing AIR and EGR Systems.mht
Old Jul 27, 2006 | 08:57 PM
linky no worky!
 Michael S. Palmer
Old Jul 28, 2006 | 01:18 PM
slow67's Avatar
Gingervitis Addict
https://ls1tech.com/forums/generation-iii-external-engine/328977-exhaust-backfires-running-rich-poor-mileage-come-air-removal.html
Old Jul 28, 2006 | 06:26 PM
Andros's Avatar
its ez, shouldnt take no more than like 30 min
Old Jul 29, 2006 | 07:45 AM
Keenov's Avatar
Yes, you need block of plates.
