Trying to track down coolant leak?
Old Jul 28, 2006 | 02:56 PM
MeanWS6's Avatar
Default Trying to track down coolant leak?
Car sometimes gets hot and uses coolant, no white smoke and no visible coolant on oil cap or engine bay. Other than pulling the heads to see if its a head gasket, what else will help to diagnose?
(if oil floats on top of water, then if I pull the oil plug slowly and just get water/coolant then this would certainly prove where this coolant is going - right???)
Old Jul 28, 2006 | 03:38 PM
radz282003's Avatar
No coolant seaping from around the water pump, or hoses? Also, check the inside the the pump pulley.
Old Jul 28, 2006 | 10:27 PM
KingOfCold's Avatar
Have you tried pressure testing the cooling system? Its usually pretty easy to spot an external leak that way. If you dont have access to a pressure tester Im sure that you can rent one from an autopart store.
Old Jul 29, 2006 | 04:58 PM
MeanWS6's Avatar
will try that, is it a pretty easy tool to use?
Old Jul 29, 2006 | 11:42 PM
GOaT Cheese's Avatar
Don't forget to test the cap also, looked over lots when the cap itself is the problem. If cap doesn't hold pressure it pushes coolant out as system pressurizes, can be very difficult to diagnose. Cap should hold 15 psi..
