cutout help
Old Jul 28, 2006 | 10:09 PM
lomaximumta's Avatar
Default cutout help
I have QTP LT's and catted Y with SLP dual/dual - I know it would be a PITA to run dual cutouts before the cats but...is it worth it to run a single cutout after the Y on the I pipe? I know it will be louder (which is good) but will it be worth all the trouble power wise?
Old Jul 28, 2006 | 10:47 PM
Starz T/A 17's Avatar
your probally lookin at around 5 HP adding a cutout but alot of times people loose torque with a cutout
Old Jul 29, 2006 | 12:59 AM
Fire-formula 93's Avatar
That setup is probably quiet as hell. I think even with the ORY that dual/dual muffler is too quiet. Spend the few dollars to get a cutout and have it installed. Total, mine was $60. It was the best $60 I ever spent, though I have stock mans. and cats. Dont bother with two, just weld one in the I-pipe before the axle. There is a "special spot" for it just behind and under the pass. seat.
Edit: I realize you are looking for more power. The cutout wont get you much, the dual/dual is a pretty good flowing muffler. I would install it just for the sound.
Old Jul 29, 2006 | 01:32 AM
DomesticLS1's Avatar
How good does a cut out sound on stock manifolds and cats? How much hp gains would it give me over using my stock muffler?
Old Jul 29, 2006 | 01:33 AM
98hardtopZ's Avatar
i think it sounds alot better ...5hp max i would think
Old Jul 29, 2006 | 02:37 AM
Over a stock muffler it will probally yeild the same gains as a good flowing catback, if you have a good flowing catback it wont help that much b/c its already good flowing, but a stock muffler flows terrible so its eating more HP so by bypassing it your gaining more HP
Old Jul 29, 2006 | 04:19 AM
old and good's Avatar
wuld it be fesable to make a steel plate that is just partialy open for the cutout similar to the borla system. for example 2" diameter hole in a plate to make the cutout not as loud or even 1.5 or 1" etc
Old Jul 29, 2006 | 04:46 AM
staringback05's Avatar
if you did get 5 out of it and some better sound....itd be worth the 35 bucks....60 for mine put on...and it sounds nice
 Michael S. Palmer
Old Jul 29, 2006 | 12:26 PM
Order 66's Avatar
You will gain about 10 or more hp and about 5-8 tq. Torque loss is a myth. The slp dual dual is a perfect catback to run a cutout on.
Old Jul 29, 2006 | 02:47 PM
^^^^ what?!...no no no
