Exhaust dilema
Old Jul 30, 2006 | 10:08 PM
General Jack's Avatar
Default Exhaust dilema
I'm losing a fair amount of hp because I'm running the dynatech supermaxx with a 2.5 inch y pipe. Rest of current system is Borla catback with solid plate in. I don't have the cats in.
I'm contemplating having a 3" customer y built to replace the 2.5". However, I was also considering just running true duals with turndowns before the axle. Would this be preferable to the 3" y to the catback?
Old Jul 30, 2006 | 10:54 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You aren't losing power unless you are making 480+ rwhp. I run a 2.5" true dual setup.
Old Jul 31, 2006 | 01:08 PM
I also run a reverse split cam which needs the least restriction possible on the exhaust side. Also, I don't have true duals, its a 2.5" y pipe.
