Headers installed then developed a misfire!
Old Aug 5, 2006 | 05:47 PM
Transam295s's Avatar
Default Headers installed then developed a misfire!
Alright having a slight issue. I had my headers and Pacesetter Y pipe installed with a TSP rumbler exhaust. I had the PCM tuned for the o2 delete as well as the egr and air. The car ran fine for about a week and then today i picked up a misfire at random times. If im cruising at like 40 and just give it some slight throttle the car misses and then backfires. At random stops it seems to miss on occasion as well but not all the time just randomly. Well as im driving i notice it sounds like I have an exhaust leak. SO i get under the car when i get home and find that the header and ypipe are leaking on the passenger side. So i know i have to get this fixed no big deal really but would this cause the misfire at anytime. The misfire really doesnt happen all the time just randomly real random. I put the car in third and punch it and get no issues with misses. Its odd. The plugs and wires are all brand new as well oil was changed it ran fine at first after the install just now have the leak and a random miss any help guys? Thanks.
Old Aug 5, 2006 | 06:01 PM
2001NBMZ28's Avatar
You didn't mention any codes. Something free and easy to check is to start the car in complete darkness and rev the engine - then look for any plug wires arcing on the headers. Pay particular attention to #6 - found that after my buddy installed his SLP's.
Old Aug 5, 2006 | 06:20 PM
gi8e7oi825's Avatar
A year after my header install, my #6 plug wire burned through causing a misfire... flashing SES light and nasty vibrations because of it.
Old Aug 5, 2006 | 10:11 PM
No codes flashing through the PCM at all. Like i said its random. I checked for arcing wire and even then did a complete inspection of the wires with no problems at all. Iv got great clearance on the plug wires. All the plugs and wires are new as well. Im going to tighten the clamp near the leak and try to stop it and see if it remedies the situation. Any more ideas would be greatly appriciated, and like i said its a random thing. THanks.
Old Aug 5, 2006 | 10:34 PM
'00_Z's Avatar
Mine ran like crap after LT install, it would bog and "misfire" under load. If I put it in neutral and revved it, it seemed fine. Finally found a loose plug wire, its been fine ever since!
Old Aug 6, 2006 | 09:14 AM
alright checked everything again this morning. No loose plugs or arcing wires. I attempted to tighten the clamp on the header y pipe with no luck still leaks not as bad but still leaking. Im thinking what i heard a miss may not actually be a miss but assosiated to that stupid leak. It apears that the engine is runs great and the hicups when the leak is at its greatest. SO im going to a exhaust shop and have them fix the leak. Any more ideas would be appriciated. Thanks.
Old Aug 6, 2006 | 01:02 PM
black00TA's Avatar
did you change your plugs when you installed your headers?
it is a must to do when doing headers.
Old Aug 6, 2006 | 02:22 PM
RevGTO's Avatar
Pontiacerator
Originally Posted by black00TA
did you change your plugs when you installed your headers? it is a must to do when doing headers.
Why? Because of the chance of having cracked one during the install?
 Michael S. Palmer
Old Aug 6, 2006 | 02:36 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
just a smart idea.
Old Aug 6, 2006 | 03:27 PM
kenkaru's Avatar
Plugs. If you really don't think so, try replacing an O2 sensor and then you'll find out later is was a plug.
PS check your plugs and wires.
Old Aug 6, 2006 | 03:41 PM
black00TA's Avatar
no, but if you can save yourself a few hours and all the bloody knuckles if you just change them while there are no manifolds on the car.
plus the swap to TR55's when doing LT's is a match made in heaven.
EDIT: what type of plugs and wires did you use and what did you gap them at?
Old Aug 6, 2006 | 03:47 PM
Full-Force's Avatar
You have had 1 of 2 things maybe both happen. You have either burned an o2 sensor harness causing it to short out and/or popped the eng sens fuse in the process.
Check that your o2 harnesses are off the headers and check that fuse.
Old Aug 6, 2006 | 11:49 PM
SweeTbone's Avatar
When did you get new front O2s for it? I'm with the fellas on the O2s, plugs and wires. Maybe the leak is throwing something off when the exhaust pulse hits the leak and reeking havoc on the O2. Not like open header oxygen sensor foul out, but depending on the severity of the leak.... Good luck.
Old Aug 22, 2006 | 10:21 PM
Problem solved. Had a busted number 1 plug and a messed up number 5 plug. Changed them and its better then ever.
Old Aug 23, 2006 | 12:33 AM
SweeTbone's Avatar
Good deal. Plugs and wires can be sneaky sneaky like that. Glad it got fixed before the Nats. Calipers look slick as **** too.
Old Aug 23, 2006 | 12:37 AM
The PAT WS6's Avatar
delte ur air if u havent already and if that dont help i would get a tune if it bothers u that much
