heeeeaaaaaderrrrrrz
thanks all
brad :
If your car is your daily driver it all depends on if your state has emissions laws, and if so how tuff. Most states have a mileage cutoff that if you are under you do not need to get emissions tested. Here is PA it is 5k a year. Long tubes will most certainly require a Y pipe. Either with or without cats, again there is the emissions thing
For more detailed info you may want to either check the Eastern forum and ask any on in VA the laws, and you can also check the external engine forum for tons of info on headers. I hope that helped some.Bob s.
