160* thermostat?
engines today are more efficient when at ~210*. they get better mpg, give off less emissions and stay cleaner. that sounds like running better to me.
You can run more adv. with out detination (knox sense removing adv.) running a cooler temp.
Last time I ran a low temp thermistate was in my IROC. 185 stat the pcm would not run in closed loop under 180. What is the magic temp in a ls1???? (or why is there not one)
Stated earlier 3.4 was more sensitive. (like my IROC) but why?
Think that is a better question.
I'm not arguing that what you've said isn't true. The OEM's are running the cars hotter for a reason. But 99% of the questions asked here are for performance reasons. There's a 12 sec club, 11 sec club, etc. but not a 30mpg club or a 0ppm club.
now maybe you're thinking "what about a blower or turbo?!" yes, that sacrifices engine longevity for the sake of gains, but you're getting HUGE GAINS! it may be totally worth it to you if you want the power. the miniscule gain of the t-stat...if any at all...tells me just leave it alone. again, JMO.
-J
As far as improving efficiency, I wouldn't really even consider going to a lower temp T-stat unless I was also going to be raising compression. Lower coolant temps provide an extra margin of safety against detonation when you are pushing the limits of pump gas. Higher compression helps the efficiency (makes more power), perhaps at the expense of longevity, but it's a compromise I'm willing to make.
I agree, there probably aren't many people out there who would spend $1000 or more for headers, lid, ported TB, cold air, etc in the name of efficiency. Sure they may achieve 2-3 mpg better, but if you're getting 25 mpg, and you can get 28 mpg for $1000, you've got to drive a lot to earn that money back.
I am sure in the winter (and when I get the Fans controlled through the ECM) it will run in the 160-170's on the move..
can we run a 50/50 mix with the Coolant or what? I think that is keeping my temps up as well, mine is close to 90% coolant..
