Adding a cross-over coolant pipe to the rear of engine with an LS-6 intake.
Old Aug 17, 2006 | 10:04 PM
squealingtires's Avatar
Default Adding a cross-over coolant pipe to the rear of engine with an LS-6 intake.
Adding a cross-over coolant pipe to the rear of engine with an LS-6 intake. Would this have any clear advantage? The #7 cylinder is notorious for problems and I can't see that blocking off the coolant pipes does any good. I've seen a single crossover in the front and in the back which were seperate but never connected. It might be ugly but has anyone re-routed the coolant lines over the intake. It could be hidden fairly well if it was routed next to the valve covers that way the intake would still be able to come off with no problems.
Old Aug 17, 2006 | 10:11 PM
DuronClocker's Avatar
Why don't you just grind down the ridges on the bottom of the intake and use a stock 98-00 LS1 coolant crossover pipe? That's what I'm doing. I just took my die grinder and ground away all of the ridges on the bottom of the manifold, and the coolant pipe and knock sensor wires fit perfect.
Old Aug 18, 2006 | 01:32 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
That's how I installed my ls6 intake 4 years ago. I just used an exacto knife and cut down the high casting ribs on the bottom of the intake. Took all of 5 minutes to do.
