vacuum line?? where does this one go??
Is there a vacuum line that goes from behind the brake booster to the engine or elsewhere???
Also I have been getting bad gas mileage lately.
If you are infront of the car the plastic vacuum hose is below and to the right of the brake booster. It is comming out of a wire loom.
Does anyone have vacuum diagram??
I'm pretty sure one end goes into a y-connector way back in the middle behind the intake, and I think the other end should have a rubber 90 degree coupler, and this end connects to a control valve which is mounted on the driver's side of the intake, or maybe on the back of the head, I forget lol. You should have two similar plastic lines connecting to this control valve.
