Heater core replacement
Old Mar 24, 2014 | 06:05 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Very nice write-up Viper BUT this is the genIII external section. Your info is vehicle specific-in this case Firebird (F-body).
SO, I've done you the honor of making your info a sticky in the Firebird section. I tweaked it up a bit and included a few things noted by Dave.
Thanks guys!
https://ls1tech.com/forums/pontiac-f...placement.html
Old Mar 24, 2014 | 06:17 PM
ez2cdave's Avatar
Originally Posted by Viper
No. I did this write up because I couldn't find anyone else that wrote up how to do a 4th gen.
"Note To Self" . . . Install BRAND NEW Heater Core while motor is out, during motor swap !!!
Old Mar 24, 2014 | 06:19 PM
Paul Bell's Avatar
Good idea! Yet another freekin thing to do during my 383 build.
Old Jul 6, 2018 | 02:36 PM
IamDovikin's Avatar
Default Replacing
I was in the middle of putting the heater core in but the pipes are slightly off to the point it wont go in. Do I need to bend a pipe and if so how?
Old Oct 8, 2018 | 07:51 PM
Redrokit8's Avatar
Thank you Paul for moving this over. This is a Godsend DIY instructional. Along with spark plug replacement this is a much feared repair.
I have a 2001 FireHawk with 30K and I know this is a winter project that is overdue. I also have the GM clamp remover but even then it can be almost impossible to get the right position to expand those clamps. Everyone make sure you aren't cutting corners too close by not replacing the old heater core lines that run from the front thermostat area. You don't want to have to repeat his exercise ever again.
Old Aug 7, 2019 | 12:17 PM
Pbarby's Avatar
Not many threads on this topic but has anyone tried removing the ac evaporator without going through the cabin? Or, what additional work is required to take out the ac evaporator?
