All charged up....
Old Aug 21, 2006 | 09:02 PM
99huggercamaro's Avatar
can i also get a pm. thanks
Old Aug 21, 2006 | 10:03 PM
HavATampa's Avatar
Thumbs up
PM sent!
Old Aug 23, 2006 | 05:54 PM
blackbird4's Avatar
HavATampa if you dont mind could I get a PM from you also? Thank you
Old Aug 23, 2006 | 07:53 PM
HavATampa's Avatar
Thumbs up
PM sent!
Old Aug 24, 2006 | 03:05 PM
TheBlurLS1's Avatar
That's what she said...
I don't think any of our sponsors sell them, POST DAT ****!
Especially if you're just going to PM it to everyone and their brother.
Old Aug 24, 2006 | 08:11 PM
HavATampa's Avatar
Hell, it makes no difference to me who knows. I've just seen posts shutdown or edited in the past due to posting non-sponsor links. I don't want the web-****'s on my ***.
Old Aug 24, 2006 | 09:00 PM
Black Plague's Avatar
Thumbs up
Hey thats the same one I am running! It really does good with load! I am using the march pulley on it . You shold see the stocker dip way down on the gauge when the rear defoger is used in the winter with the new alt at dosent go down at all. Be sure to get the upgraded power charge wire for it!
Old Nov 12, 2006 | 04:29 AM
1 BLOWN V8's Avatar
Double post
Old Nov 12, 2006 | 04:33 AM
1 BLOWN V8's Avatar
Its time for me to upgrade to a HO alternator my dual bottle heaters is killing my alternator and at idle I cant even get the bottle pressure up at all. So I need a link to where you got this. Also did you upgrade to the 4" wire?
Old Nov 12, 2006 | 08:37 AM
WILWAXU's Avatar
Yeah.. but your more likely to get banned for asking people to PM you for a non-sponsor information
You can share information without promoting the non-sponsor
Old Nov 12, 2006 | 09:06 AM
Bad30th's Avatar
That's the same alternator I just got - I can tell by the sticker in the picture. Mods please edit as per policy if required.
It's from 4alterstart dot com who is highly recommended in the Electronics/Stereo forum of this board.
There is a vendor who sells them as well, Afterthoughts Auto has a 160a alternator that you can order in different powdercoat colors.
A word of warning - you have the bigger B4C (police unit) housing on that alternator, it won't fit with the standard ATI blower kit mount. I had to send my 200a alt back to them and exchange my 200a for a 180a in the stock size housing (even called first and talked to them before ordering, they just didn't have experience with the ATI kit I guess). You don't need to use the black plastic cover from the old alternator (won't fit anyway), but you should probably upgrade the wire between your alt and battery with a heavier gauge beefy wire - the stocker is pretty puny.
This new alt solved my voltage drop from adding my new 9" spal fan, and also solved my fuel pressure issues (55psi and dropping -> 60psi steady).
Rob (Bad30th)
Old Nov 12, 2006 | 09:15 AM
  #32
Bad30th's Avatar
Originally Posted by 1FST99Z
what output is our alternators stock?
105 amp, and a pretty low output at idle.
Rob (Bad30th)
