Overheating Problem
Old Aug 22, 2006 | 01:11 PM
eyedrron's Avatar
Default Overheating Problem
I'm having trouble with my LS1 overheating when at Idle. I am running a new four core aluminum radiator with electric fan. If I bring idle up to around 1500 the temp will return to normal. Its like my water pump is not producing enough flow at idle. Any suggestions or do they make a high volume pump for the LS1?
Old Aug 22, 2006 | 01:25 PM
rickyracer25's Avatar
check the t-stat, could be stuck until there's enough pressure
Old Aug 22, 2006 | 03:05 PM
Gearhead1's Avatar
Are you running an underdrive pulley?? If so, try the stock one and see if it helps.
