ls1 vs. ls6 intake
Old Aug 22, 2006 | 08:52 PM
ls1transam346's Avatar
Default ls1 vs. ls6 intake
i was wondering how you can tell the difference between an ls1 and an ls6 intake manifold
Old Aug 22, 2006 | 09:12 PM
iamsickofitall's Avatar
the ls1 intake is on the left, the ls6 is on the right
on the TOP part of the intake, the ls1 will have the EGR plugged into the front just behind the tb. that is the easiest give away, but be careful because some older vette intakes are ls1's with no EGR so you need to check the bottom
Old Aug 22, 2006 | 10:15 PM
Luna's Avatar
Question: The wood or foam you see under the intakes. Is that there stock or is that something people put in there? Is there a point to having it there? The intake I got doesnt have that stuff but I can tell where it used to be.
Old Aug 22, 2006 | 10:25 PM
it's just to keep crap from sitting underneath the intake
Old Aug 23, 2006 | 12:58 AM
The PAT WS6's Avatar
ls6 is flat on the bottom and it has bigger ports
Old Aug 23, 2006 | 07:08 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That picture needs it's own sticky!
Old Aug 23, 2006 | 07:49 AM
staringback05's Avatar
hmm^^....yea so one of the easiest ways to tell the difference is the egr and that little dip in the manifold itself
