cut camaro grille for better cooling?
my question is, there is a black shroud on top of the AC crap and radiator. (under where the wiper fluid reservior should be). am I supposed to remove this? it seems like it would allow more air to directly hit and pass through the radiator (ie: better cooling), but is there a downside? like allowing more hot air into the engine bay? or just something that I haven't thought of?
Do you have a large front mounted intercooler or the two small ones to the sides? The front mounted one would be the only reason to cut the front of the bumper out. It's not going to help with engine temperature just intercooler temp.
The black diagonal shroud in the front directs air to the radiator leave it in. F-bodys get their air from the bottom not through the front.
im going to seal the top of the rad and a/c rad w/e off better so it goes through them and not over also..
i dont have any cooling problems im just taking most of the stuff of to make it more efficient or more room and less weight on the front end.
