3.5in Collector to 3in Xpipe system?
Old Sep 5, 2006 | 06:42 PM
Speed Density's Avatar
hashtagBMW
Default 3.5in Collector to 3in Xpipe system?
Car is a 396 Stroker, big heads, big cam, big shot. Thats being subtle.
Anyway right now the car has 1 3/4-1 7/8 Stepped LTs with 3.5in collectors and im trying to go easy and do the summit x pipe kit.
They only offer 3in at most thought. Is that smart to use? Collecotr wont be able to scavange very well with a .5 drop right after it.
If not im going to have to fab a 3.5/4in kit up.
Tony.
Old Sep 6, 2006 | 02:11 AM
hashtagBMW
b U M P
Old Sep 6, 2006 | 02:30 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
3.5" is huge even for a 396. I think that you should be fine with the 3" honestly.
Old Sep 6, 2006 | 08:42 AM
V6 Bird's Avatar
Negative..
I noticed substantial gains on a stock long block 346 with a decent size nitrous push...im talking up to 40 hp gains in some spots of the curve..
Ive always used the rule of thumb to match the collector size to the size of junction...
3.5" collector gets a 3.5" crossover/X-pipe setup....I ran 3.5" duals dumped at the axle on my car it was well matched.
If theres one thing ive learned over the past 5+ years messing with exhaust setups and LS1s in particular...You cant over exhaust an LS1.
Old Sep 6, 2006 | 06:36 PM
dug's Avatar
dug
how did it sound?
Old Sep 6, 2006 | 07:50 PM
hashtagBMW
Lt1 fellas.
Old Sep 7, 2006 | 02:26 PM
V6 Bird's Avatar
Originally Posted by Speed Density
Lt1 fellas.
have you ever heard of anyone over exhausting a SBC either? prolly not
Old Sep 7, 2006 | 02:31 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I had the same headers, and ran 3.5 pipe into a 3.0 Kooks X pipe. We got all the pipe from Kooks. I made 754rwhp with my old blower setup @ 6600 rpms.
Old Sep 7, 2006 | 06:03 PM
hashtagBMW
Well I guess I can mandrel bend some 3.5 and run a 3in junction and then 3in mufflers and dumps.
Old Sep 9, 2006 | 05:10 PM
hashtagBMW
b U M P
Old Sep 9, 2006 | 08:20 PM
00454sscamaro's Avatar
im interested as well, but from the looks of it i am going to hafto go look at a local speed shop to see if i can get something fabbed up, or just see if they got tubing and benders big enough. i know they do 3" wich is bigger then any actual exhaust shops around here... they look at you like your from another planet if you say anything above 2" at the local meiniki or w/e it is.
