Help, steering knuckle rubbing headers!
Old Sep 9, 2006 | 12:17 PM
SPECIALIZED STAINLESS's Avatar
Default Help, steering knuckle rubbing headers!
I put LT Pacesetter headers on my 98' Camaro Z28 and I had to dent the header a little and grind the steering knuckle to get it back on. But it still rubs pretty bad. Has this happened to anyone else?? How do I fix it? Thanks, Steve.
Old Sep 9, 2006 | 12:34 PM
slow trap's Avatar
is it the astual knuckle or the tubing that is rubbing ? you might be able to loosen your header bolts and try to raise the header alittle.
Old Sep 9, 2006 | 01:40 PM
cncbird's Avatar
had the same problem on a ta that had been wrecked. there are 2 different racks for these cars.put the right rack on it and the steering arm was at a diffefent angle and it cleared fine.this was after about 2 days work, denting the header about 1/4 way shut and trying several suposedly right racks from auto zone.got a used one from a z/28 and has over 1" clearance--other one's must have been from 6 cyl cars.
Old Sep 9, 2006 | 05:52 PM
What are racks?? I think this is my problem. Do you have a pic? Thanks
Old Sep 9, 2006 | 06:05 PM
BLKWS6's Avatar
stearing gear ....rack and pinion...
Old Sep 9, 2006 | 07:57 PM
Is it hard/ expensive to replace the rack and pinion?
Old Sep 9, 2006 | 08:30 PM
00454sscamaro's Avatar
nope, pretty simple and i think its around 100-200 bucks was awhile since i got a replacement one.
