LS6 Head and Cam packege.
Does GM Performance LS1 to LS6 convertion with the heads and cam realy make 405 Horses? Is it on the wheel or on the crank?
Does it worthed or are there better options?
I have the 2001 LS1 in my 67 Camaro and like to improve the power little bit more.
I figured should get your opinion on this bec. there is no other place then this about LSX engines.
Thanks
Ismail
Also, I'd assume the 405hp is rated at the crank if this is what the z06's were rated at for flywheel hp.
The reason I want this is that it is reliable. I'm not after a very lumpy racey sounding motor.
Any suggestion about LS6 ported and assembled head and cam combo which would be reliable and sound not so lumpy?
Thanks
