O2 Sensor spliced extension mess up
Old Sep 17, 2006 | 11:34 AM
dpren's Avatar
Default O2 Sensor spliced extension mess up
So I just installed a set of headers the other day. The very last thing I did was splice in some extensions for the front O2 sensors. I was in a hurry and didnt notice that I extended one front O2 sensor and one rear O2 sensor. The car worked fine for a couple days but now its runs like ***, it stalls and sputters like crazy. I dont know which sensor actually belongs in the front, All I know is I have two sensors sitting in my garage one with a long lead and one with a short lead. Can some one tell me how to tell the front and rear sensors apart.
The stickies told me I F***ed up by using a rear O2 in the front, but not how to tell them apart.
Thanks,
Old Sep 17, 2006 | 12:39 PM
2001bluerata's Avatar
Just go spend the money and buy 2 new front ones and be done!
Old Sep 17, 2006 | 12:59 PM
2xLS1's Avatar
The problem is probably with your splices, not which sensor you used. The 4 sensors all function the same. Only difference is the wire length on some. Go buy some real extensions and use the sensors you didn't cut, or buy the Vette rear sensors with the longer wires.
Old Sep 17, 2006 | 01:12 PM
HotWhipT/A's Avatar
All four of mine looked identical. I knew which ones where the rear though. The rears were dirtier because they don't get as hot to burn off the carbon.
I did figure out that if you try to soder and shrink wrap, the soder doesn't work too well. I can soder really good, but I was having a hell of a time. I then figured out it was because the O2 wires are steel and I was using copper. The soder would go to the copper and not to the steel. The steel wouldn't heat up enough to melt the soder.
