Need Help ASAP!!!!!!!!!!!!!!
Old Sep 17, 2006 | 04:05 PM
ws6102488's Avatar
Default Need Help ASAP!!!!!!!!!!!!!!
Just bought 2001 ss put full exhaust lid and ported tb and maf The day bought car got home went to drive it again and it started sputtering when u nail it then it will clear up and go. Today i switched everything i could thank it could be i changer plugs, wires, fuel filter, sea foam treatment, changed the maf everything i can thank of. What else can cause this to happen. I have also changed the coil pcks too. Please help. Thanks roger
Old Sep 17, 2006 | 04:14 PM
SLP LS1's Avatar
MAF, when I put my SLP MAF on, it did that! Computer had to reprogram itself, then worked fine. But, I ended up going back to the stock MAF because it fits better with the application I'm running.
Also could be the Throttle body sensor, mine went bad and it did that. I went to the dealership, they replaced it and everything was alright again
Old Sep 17, 2006 | 04:35 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It could be one case of "You jacked with the MAF, and now you get the short-end of the stick". I would get a stocker and put it back on. I still don't understand why people want to get a bigger MAF on a virtually stock setup. That money could go towards other mods easily.
Old Sep 17, 2006 | 04:37 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Sending over to the External Section. Everyone will tell you virtually the same thing. You might have leaned out your motor or have a damaged A/F table now.
